Upgraded my OG steps this season to these Confer steps... nothing wrong with the first ones, I just didn't like them. But, luckily, my friend can use them in her AGP, so it'll work great for her.
SO, as I was unboxing and assembling the new steps, I realized I ordered the WRONG ones.
2 weeks of research on Amazon, my research here, and an ill-timed ADHD brain short-circuit, and well, here I am with not-my-first-choice steps... My hubs said, and I quote "you get what you get, and you don't throw a fit."
They assembled well-enough and I weighted them with the gallon jugs of sand/rock (re-used from last year). They will be fine steps.
The solid side-walls on these steps are my concern. I drilled some extra holes all around the sides to help with water flow, but I'm still nervous that it'll be a nightmare trying to keep the area clean. Can't really get behind it with a brush, so Jetting out muck with water hose, detaching the steps from the deck for scrubbing/vacuuming are about my only cleaning options I can think of.
The return jet is to the left,about 4ft, with the water flowing toward the ladder. Not ideal, but is what it is.
Would aiming the return DIRECTLY at the ladder be beneficial at all? Or would it slow down the flow/circulation too much?
I typically have the return positioned at a 45 degree angle, just high enough to ripple the water. And honestly, I don't even know if that's right?
I'm needing some suggestions/solutions/"here's what I did" to ease my mind!
Sidenote: It's been so COLD in OK, I haven't even been able to get in the dang pool yet!
