Let me start off by saying I’ve been living the TFP life for about two years with our pool. I’m all in and love it, even put others on to it. The pool is dialed in, other than some brushing and dropping in MA every so often, it’s fairly, well, trouble free. So thank you all for that.
Now on to my issue. We ordered a new spa, a Master Spa Twilight Series 8.2, last October, and after a nearly 14 month wait it finally arrived this past Tuesday. We filled it, did an Ahhsome purge, drained it, cleaned, refilled, added chemicals to balance it and started using it the next day.
My issue is it’s going through FC at a fairly high rate. I’ve always been one to keep our pool on the high side of the FC window, and I was looking to do the same with the new spa, but it’s been troublesome, for lack of a better term. I read the stickies on this forum to get myself educated and ready for the spa to come. I used dichlor for the initial phase of sanitizing to get the CYA to 30. I was diligently logging my additions to know when I hit 30ppm, which happened yesterday and I was able to confirm it by doing a CYA test, and the dot went invisible just at the 30 line. I’ve now switched over to liquid chlorine, bleach actually at 7.5%. (I have questions about that, but I’ll save that for later to not confuse this post)
During the day I’m having to add LC multiple times to keep the FC above the min for 30 CYA. My CC has never been above 1, and usually goes down to .5 or what looks like lower after I’ve dosed with LC. I’ve gotten the TA down to 50, and have boric acid on the way to get some borates in it, but honestly the ph has stayed fairly constant the last day or two, at 7.4, occasionally and temporarily at 7.6. I suspect it’s giving me 7.6 if I take the sample while the jets are on, and 7.4 when they are not. Admittedly, I may be taking the sample too close to the surface that may be causing those spikes to 7.6, with a return to 7.4. I’ve never added ph up, so I don’t why it would go up other than aeration, but the drop back down to 7.4 is a little strange, but those are my theories as to why.
Each morning it has 0-.5 FC, to which I immediately bring it up to 6ppm or so. Today I went ahead and took it to 11ish ppm and tried to keep it there most of the day to maybe try to kill off whatever could be causing it. I know this isn’t a full slam, and maybe that’s what it needs until it meets the exit criteria, but honestly I’ve never had to slam my pool, so I’m a little new to it.
The spa does have an ozone generator, and I think I read that can consume FC, but other than that I’m not sure what I may need to do. The tub has only been filled for 5 days, and I feel like I’ve been on top of it. Any thoughts or suggestions?
