Greetings,
Several months ago we moved into a new house in San Diego. The pool had been "maintained" by a pool guy who, for all intents and purposes, simply showed up once a week and dumped in a gallon of liquid chlorine.
My first order of business was to break down and inspect the DE filter, which supposedly had just received a top-to-bottom cleaning by the pool guy. What I found was a disgusting, epic mess. Both of my pool-owning neighbors were mortified.
Following that situation, I fired the pool guy last month, and began taking care of things myself.
To this point, I have been using Clorox 3" chlorine tabs in a floater, along with Arm & Hammer Stabilizer, PhosFree and a few clarifiers. This seems to have worked just fine for the past month or so, based upon test strips and water analyses at my local Leslie's.
But...
As I have read more and more about water chemistry on this site, I have come to learn that:
-The chlorine (dichlor?) tabs also contain CYA, and using liquid chlorine is far preferable;
-The Arm & Hammer stabilizer also contains clarifiers, which can clog my DE filter;
-Phosfree is unecessary in a well-balanced pool, and can also clog my DE filter;
-Clarifiers can clog my DE filter, and are just generally unnecessary with DE filters.
As such, I've decided to get serious about all of this, and order a Taylor K-2006 FAS test kit - and rethink my chemical product set and weekly maintenance routines by eliminating all of these complex and often unneeded additives by keeping things as simple, reliable and pure as possible. Just the chlorine without the CYA, just stabilizer without the clarifier, etc.
To this end, I am hoping to get some recommendations on how to transition over to this more informed way of managing the pool on a dependable, cyclic basis without a whole lot of trial and error.
Thank you in advance for your help!
But...
