So the timer on the right goes to the pump in question. Before replacing the pump today everything worked perfectly. Nothing was changed but the new pump. FYI I did pop the breaker on first startup. The ground wire was touching a hot. Possibly this messed up the timer. I can confirm the timer is moving and keeping time. It just does not turn off the pump.
I agree with Allen... The timer is now toast... The contacts that normally open and close to turn the pump on and off are welded together... Kind of how an arc welder works...
Note that you can replace just the timer mechanism. Look up the parts diagram for your model. The mechanism just snaps in and out. You can check the contacts on the back.
You can probably unstick the contacts, but once they get burned, they are more likely arc every time they open and close.
