new pump recommendation wanted
ActivFam
Active member
Jun 30, 2018
30
Minneapolis, MN
Pool specifics listed in my signature. What brand pump and horsepower do you recommend for our pool size? Our original pump is probably nearing the end of its life and would rather start the season with a new one.
mknauss
31,092
Laughlin, NV
A two speed motor would be something to consider. It will reduce your electrical cost. The wild card is if the flow rate on low speed will be enough for your heater. Hard to predict that.
Reactions: ActivFam
mknauss
31,092
Laughlin, NV
Your pool does not need a 2 hp pump. Now if you get a Variable speed pump, you get the best of all worlds as you can dial in the rate needed to operate the heater, etc. But VS pumps are more expensive.
Stand alone pumps (not ties to an automation system) can be from any manufacturer. You have the big companies, Pentair, Hayward, etc, that must be installed by a dealer/professional to get the full warranty. You have InyoPools, Circupool, etc that have quality pumps and provide more generous DIY warranties. Your current pump is a Waterway pump. InyoPools markets those and I believe have replacement motors, even two speeds, that will mate up with your current wet end. Call them.
