Using yourcyest kit, do a test fir:
- FC (Free Chlorine)
- CC (Combined Chlorine)
- pH (potential of Hydrogen)
- TA (Total Alkalinity)
- CH (Calcium Hardness)
- CYA (CYunaric Acid)
- Pool water temperature at time of test
Once you have numbers for each of those, folks on here can advise on next steps.
If you spill during stirring, restart...
Remember, align water line to volume marker on tube, with lowest point of water level (remember, meniscus rules)...
Using FAS DPD kit:
1. FC:
Fill block large tube to 10mL of pool water
Add 2 scoops of R-0870 powder
Stir well
Add R-0871 counting each drop, while stirring. Stir after each drop added. Once sample turns colorless and stays there, don't add anymore.
Multiply # of drops added by 0.5.
Result is FC in ppm (parts pee million).
Don't throw sample out, continue to use for CC test.
2. CC
Using sample from previous test,
Add 5 drops of R-0003
Stir well
If sample turns any color, add R-0871 while counting drops, until sample turns colorless again, stirring between drop adds.
Once sample colorless, multiply # of drops added by 0.5.
Result is CC in ppm units.
Discard sample and rinse tube with pool sample water to prep for next test
3. pH
Add 44mL of sample water to large tube
Add 5 drops of R-0004
- Close cap, don't shake, invert tube gently couple times.
- Hold up tube to Northern sky. It helps to have white paper as background
- compare sample color to pH chart colors on block.
Result is your pH
Rinse tube to prep for next test
4. TA
Fill large tube to 10mL mark
Add 1 drop R-0007 and stir
Add 3 drops R-0008 and stir
Sample will become green.
Add R-0009 counting drops, stirring between each drop, until sample turns red. Once turns red, add 1 more drop. If color changed more, count the extra drop. If color did not change, do not count extra drop.
Multiply # of drops by 25.
Rest is TA in ppm units.
Rinse tubevin prep for next test.
5. CH
Fill tube to 10mL mark
Add 10 drops R-0010 and stir well
Add 3 drops R-0011L and stir well
Sample will turn red.
Add R-0012 counting drops, and swirling between drops.
Stop counting once sample turns blue.
Add 1 more drop. If sample still changes color, count the extra drop. If no color change shown, do not count extra drop.
Multiply # drops by 25.
Result is CH in ppm units.
Note: sample may turn purple. Purple means there are metals present in your water. It may be difficult to see color change. You can repeat test by adding 5 drops R-0012 first then swirl. Then add 10 drops R-0010, stir, then add 3 drops R-0011L, then add R-0012 counting initial 5 drops plus additional ones, til liquid turns blue/purple. Same rule for extra drop applies.
6. CYA
Fill cya test bottle to 7mL mark with sample
Add R-0013 to 14mL marker on bottle
Close cap and stir for 30 seconds
Open bottle spout, slowly start filling small block tube with sample. Stop filling as soon as the black dot at bottom of tube disappears.
Read measurement on side of block tube.
Result is your cya in ppm
Note: If dot does not disappear, means your cya is very low.
Hope this will help you fo the tests and let us know so we can help.
CAN SOMEONE GIVE ME A LIST OF RECOMMENDED CHEMICALS TO GET STARTED....
