Good morning!
We were just cleared to begin our water chemistry management yesterday following the installer's "Pool School." I thought their pool school balanced the initial chemistry but that wasn't the case. They just walked me through all the equipment/maintenance and shook my hand.
I've lurked on TFP for several months and studied hard at the TFP Pool School before signing up and downloading the Pool Math app. Had our water tested a week ago at Pinch-a-Penny just to see where our "tap water" was at and then tested it yesterday with a 2006C kit before getting started. Not a chemist but I'm very comfortable with following directions....I'm a quick learner.
Pool is a 19k gallon gunite/PebbleTech pool with an ozone generator. Pool was initially filled 3 weeks ago, water is crystal clear, and we're still daily brushing for another week. PH was high off the chart and CYA/FC was zero. I added Muriatic acid to start bringing down the PH and am using 3" stabilized tablets to start raising CYA while adding FC. Once the CYA is up to ~40ppm, I'll switch to liquid chlorine.
Does stabilizing PH and FC while slowly bringing up CYA sound like a good plan before we address low CH (and everything else) or should I attack everything at once? My thought is to slowly balance everything since water temp is 60 degrees. Thanks in advance for your expert advice!
