- Jul 21, 2013
- 66,082
- Plaster
- Pentair Intellichlor IC-60
@proavia @jimbethesda @ajw22
Sounds like I will be upgrading the pump to Pentair Inteliflow. Is 2" piping going to be ok to handle the pressure from it?
Schedule 40 PVC pipe is rated for over 300 PSI pressure. A pool pump cannot create that much pressure. The pipe is not your weak link.
You need to change your sand filter and MPV which limit you to 60 gpm. The IntelliFlo VSF pump can do over 100 gpm if unrestricted.
