Hi! We are in the process of building our first pool in TX and seem to be running into a lot of issues with our pool build. They act like everything is fine and normal but I’m starting to wonder how much I need to push back. The pool is basically done but as soon as it was filled with water 2 weeks ago you could see that it wasn’t level by the water line on the tile. When I pointed this out to our project manager he blew me off that it was just a cosmetic thing. Then when we turned on the spa spillover water only spilled over one side making it pretty obvious that the pool isn’t level. They shaved down one side of the spillover so it would function correctly but now the tile is obviously crooked because they had to make the wall uneven so that it was level in a crooked pool. Now the pool builder is admitting that pool is crooked but are blaming the soil and saying the pool shifted even though we did soil injections. My questions is should I be concerned that pool has already shifted if that is the case? Or is it more likely that pool was just poorly installed? Any advice or direction would be much appreciated. I don’t want to overreact but I’m so nervous that this is going to turn into an even bigger headache down the line.
