Hi All,
I’ve got a new pool and my PB went MIA at the end, so it’s up to me to get up to speed. This is not my first pool, but this pool is different than my other pools in that it is raised and the equipment is underneath it.
Today’s project is getting the chemistry on the right path. This isn’t new to me, so I’m following the process. I‘ve never had to take a pool from zero CYA to the appropriate levels, but there is a first time for everything. I’ve got the app, I’m doing ALL my tests, heading to the store and will follow the process for all of my levels.
Now on to my first batch of questions.
- I’m not sure how to determine the appropriate pump speeds. We have 2 pumps.
- We have an in-floor system. It runs 100% of the time. Even when the spa is on. It drives me crazy. Sitting in the hot tub, the in-floor comes on and jets pummel people with cold water. The in-floor isn’t connected to the button in the control panel so turning that off/on makes no difference.
- We have a chlorinator. I’m assuming the appropriate pump needs to run at a specific speed to make that work best. If so, how do I determine that?
- We have an overflow basin. It gets dirty. I have a robotic vacuum. Any tips/tricks to keep that clean? It seems to collect all dirt/stuff in there.
- The air blower is not attached. Should this be attached using PVC glue or some other way?
Thanks for any help you can provide.
