I purchased a home that has a 20x40 in ground pool a month ago. I see the plumbing and filter system and literally don't know what is what. I don't know why there are two pumps, or what the various valves are for. Could someone please explain what is what in these pics? Thanks in advance!
The white pump is your main pool pump. The black pump powers your pressure pool cleaner.
The 3 valves with lever handles are on 3 suction lines into your pool pump. How many skimmers do you have and do you have a main drain? If you have 2 skimmers and a main drain it is likely one pipe is for each.
Is the pump running and water circulating through the pool now? I am not familiar with those valves but think they are all closed.
The small grey space ship device is Zodiac/Jandy Mineral dispenser... The very first thing I would do is remove it...
Here at TFP, we believe that the best sanitizer is plain old chlorine... You won't find much support for mineral systems here as they just do not work as advertised. If you don't have a sanitizer in your pool water, it will quickly turn green...
Another point, just in case you did not know already.. You have a single speed pump.. When reading this site you will see a lot of info about Variable Speed (VS) pumps because they only use about 25% of the electricity to run...
I would assume in your location, it is time for you to get the pool closed for the winter.
Boy are you in the right place! Our experts will talk you through closing the pool. Then you'll learn how to take care of it next year with dirt cheap with generic chemicals. But next you can start your Christmas list:
