I will do that this weekend when I’m finally home in the daylight.FYI == you should test your CYA in the bright sunshine with the sun to your back. But for now (winter), you can use the 30 ppm result you just got.
CYA - Cyanuric Acid Test
Cyanuric Acid (CYA) is the chemical name for what is commonly referred to as Stabilizer … Read more…www.troublefreepool.com
I know doing it inside even under daylight bulbs isn’t accurate and I do want to be as much as possible. I’ll be retesting everything then.
Given the huge assortment of pool store chemicals left behind, and my own neglect, I was expecting the chems to be way, way off. Rather shocked the CYA isn’t through the roof. If the dog hadn’t eaten the puck floater, I’m sure it would be! The fact that I’ve done nothing but rake, brush, run the robot if I felt like it and twice toss in a little stabilized shock hasn’t helped much but the water is in much better shape than I expected.
It was fun playing chemist and getting a good feel for everything. I’ll get a plan for winter maintenance together this weekend. No one will be in the pool anytime soon but if I get and keep it balanced now, it will be easy to take care of the minor algae issue I have come spring. No sense letting it go to a swamp and fighting that.
I’m shopping for a SWG and leaning hard toward the CircuPool Universal. Undecided on the 40 or the 55. I don’t need fancy, just functional and reliable. I found the paperwork for the new liner and those measurements don’t match my own. I’m somewhere between 22,000-28,000 gallons and that’s a big difference.
Also looking into replacing the old single speed pump with a variable speed. If I can’t swap just the motor, I’ll have to replace the whole thing.
At some point next year I’ll also need to get a safety cover so I can close the pool come fall. It’s only open now because of the dogs.
It’s a lot of $$$ for me to lay out and I’ll need to grab the best bang for my buck spacing it out as I can afford it.
