Little update: My levels as of this morning are:
FC: 10.5 ppm
CC: <=0.5
CYA: <30, still building
The sock with stabilizer has been hanging in front of my filter return jet for about 36 hours, and almost all of it has dissolved, but there’s a little bit left to go, so I’m not surprised it wasn’t up to 30 yet. As for CC, not sure if that’s good or not. After adding the 5 drops after the FC test, the solution did turn light pink, but a single drop of the R0087 turned it back to clear.
FC has been steadily dropping since I began, so I’ve had to add a little chlorine every test! I just added enough to get back up to 12 (maybe slightly more).
The pool itself is still green, of course, but it seems to show slight improvement, which is a good sign. We can see the bottom a little more clearly now! I’ll attach pictures below:
FC: 10.5 ppm
CC: <=0.5
