- May 3, 2014
- 62,727
- Fiberglass
- Pentair Intellichlor IC-40
Good point, I initially turned it down from boost to 70% I'll leave it at 100%. I'll retest tonight or at least tomorrow morning.With a CYA of 90, your FC should target 7 ppm or higher.
Just curious how did you get 3572 for your salt reading? Never mind I just read you have a meter.Fc: 5
Cc: 0.5
Salt: 3572
PH: 7.6
Ta: 110
Ca: 400
Cya: 85
I have a problem with liking tools, I bought the salinity meter to confirm the Taylor. Having a hard time justifying keeping it when it's several times more extensive than the Taylor. Hopefully won't need to test for salt as often once I get this figured out.Just curious how did you get 3572 for your salt reading? Never mind I just read you have a meter.
Depending on over flow from rain and splash out from swimmers you may not need to check salt levels. It's just my wife and I so I don't really ever check ours.I have a problem with liking tools, I bought the salinity meter to confirm the Taylor. Having a hard time justifying keeping it when it's several times more extensive than the Taylor. Hopefully won't need to test for salt as often once I get this figured out.
Where you charged for these bags or was it just mentioned in the inspection report? If you were charged for 6 bags a few weeks ago and your salt was 800 that seems a bit suspect. Also that would explain the need for pucks, if there was no salt in the pool, which I am sure they charged you for. No salt no chlorine. Just something that stuck out when you were describing your situation.So I found an inspection from a pool company from a few weeks ago that mentioned 6 bags (40lbs each) of salt, so there's another piece of the puzzle. Based on the app 800 ppm -> 3000 ppm would be... 239 lbs of salt.
Nothing was charged, those were recommendations, but we decided that we were going to give taking care of the pool a shot.Where you charged for these bags or was it just mentioned in the inspection report? If you were charged for 6 bags a few weeks ago and your salt was 800 that seems a bit suspect. Also that would explain the need for pucks, if there was no salt in the pool, which I am sure they charged you for. No salt no chlorine. Just something that stuck out when you were describing your situation.
We have about the same size pool, if I leave the SWG on 100% I will have a chlorine reading of 15-20 ppm the next day. Turn on the SWG and crack open the pipe directly downstream of the SWG and take 10 ml of the water dripping out of the pipe you cracked and test that. It should read substantially higher than your current pools chlorine levels, that will determine if the SWG is working. My Jandy SWG will not operate @ low levels of salt, it immediately gives me an error. Double check your CYA, it's the most difficult test IMO to get correct. If the CYA is low, the SWG will have a difficult time keeping up with the chlorine loss...
First, turnover is a myth. You run the pump, in your case, for two reasons. First is to create chlorine with the SWCG, second is to skim the surface.
That flow rate is crazy high. If you like to use that much electricity, go for it. But there is no way you need that rate to close the flow switch on the SWCG or skim the surface of your pool.
The TFP FC levels are based on the FC/CYA ratio. What they told you is the standard industry same FC level no matter what your CYA.
The SWCG is not more efficient at any flow rate other than that needed to close the flow switch. I suspect that will occur at about 15 gpm.Since jandy notes that the SWG is most efficient at 40-50 GPM
Just got the electricity bill for the last few weeks...yah its definitely going to get changed.The SWCG is not more efficient at any flow rate other than that needed to close the flow switch. I suspect that will occur at about 15 gpm.
