Billy,
Nice looking pool..
Show us a pic of your equipment pad that will give us some better ideas.
I am one of those members that runs 24/7/365. I do this for several reasons...
It works best for me.
I have a Saltwater Chlorine Generator (SWCG) that only makes chlorine when the pump is running. I like to make a little chlorine all the time.
I like to skim all the time. Running the pump keeps the water moving past my skimmers so I rarely have anything floating on the surface of my pool.
I like quiet. I run mostly at 1200 RPM and at that speed you almost have to touch the pump to make sure it is running.
The cost for me to run 24/7 is way less than $20 bucks a month and I have an old pump. New ones are a lot more energy efficient.
This is what works for me. You will need to determine what works for you.
I can run at 1200 RPM because I do not have a heater. If you have a heater you will need to run at 1600 or more. It just depends on your plumbing.
There is no requirement to run 24/7. Some people only run their pump for a few hours a day.
Don't get caught up in the idea that you have to "Turnover" x amount of water per day to prevent algae. It is just not true. You either have algae or you don't. Pool filter are not there to prevent you from getting algae, they are they to capture all the junk that falls into your pool.
I see this is your first post. You should take a good read through our Pool School and you will find that we are very different than most pool web sites. Our goal is to teach you how to use science to take care of your pool, instead of going to the Pool $tore and buying "magic" in a bag.
We'd be glad to get you pointed in the right direction.
