Hello,
We're doing a new backyard living space, with a pool. I've attached a very high level concept drawing. We're talking to a lot of contractors right now, and an engineering firm - since we have a large easement for a detention pond in our backyard. So we have to modify that pond to maintain capacity if we use any of the easement.
Most of the numbers I'm seeing from different contractors are pretty consistent, at least for estimates - we haven't gotten far enough into the design process for binding quotes yet.
One thing we want to do is a smallish pool house (~ 18x10) with a bathroom, shower, and changing area. The high level quote I'm getting for this is $75-125K. On the low end, that's over $400/SF, which seems surprisingly high.
When I asked him about this, this was his reply:
" In regards to the building, the square foot price would be much higher due to working in a small space. Large houses allow for several crews to work in several areas at once for much higher efficiency rate. If you would compare the square foot cost on your typical bathroom remodel for instance, you would find the same type of expense. Working in a small space such as this pool house and conducting all the same services you would for a home build: foundation, framing, dry wall, finishing, roofing, lighting, bathroom installation, and most importantly the utilities makes for a much slower and more labor intensive build driving up labor costs. The utilities as mentioned before are a typically a large expense as well. The expense for the bathroom alone could range up to $50,000. You have storm water for the gutters, sanitary for the shower and sink, water, electric, and sometimes gas that all need to be attached to the main lines to your house that sometimes can be buried 8' deep, grinder pumps sometimes needed for the sanitary lines, and if your electric panel is over loaded an additional electric service may be required from the power company as well. "
Is this rational? I was really expecting something around $150/SF, assuming there wasn't some huge problem in getting access to sewer, water, etc.
Thanks - I'd appreciate any input.
Parag
Parag
