New pool in central Houston
sangria
12
Houston, TX
Trying this again, I think I somehow deleted my prior thread. Have been reading a lot on this site for over a year, let me know if you have any comments on the below! Thank you.
Jimrahbe
19,808
Bedford, TX
S,
Welcome to TFP... A great place to learn all about how to care for your new pool.. :shark:
Hard for me to read, but it "appears" you are getting a T-3 salt cell... If so, I doubt it is big enough for your pool... A salt cell has to be at least 2 X the volume of your pool. I believe the T-3 is rated for a 15K pool, but in reality you will need a bigger cell, especially in Houston.. Cells are rated when running 24/7 at 100% output. Something you really do not what to have to do..
I like your large filter and VS pump.. A VS pump is almost mandatory for a saltwater pool.
I also like the geometric shaped pools..
Good luck with your pool build,
sangria
12
Houston, TX
S,
Thank you - yes it is a T-3 salt cell. Since I have the automatic pool cover, I thought I might be able to get away with a smaller salt cell, but I will bring that up with the builder. Thank you for your comments!
Jimrahbe
19,808
Bedford, TX
S,
Sorry, I missed the automatic cover... So then the T-3 should work.. there is no real downside to going up on the cell size other than cost and I doubt there is a lot of difference between the T-3 and T-9.. The larger the cell longer it should last.
kimkats
47,360
Tallahassee, FL
Hi and thanks for letting us help you spend your money build your pool!
Do you have a detailed plan for the pool for sure things as placement of skimmer, returns, and lights?
Have you seen these main drains? Retrofit Pebble Top Drain Covers — Color Match Pool Fittings so pretty!
Make sure there is a light over your equipment. You will thank me the first time you have to go out there when it is dark!
Kim:kim:
YippeeSkippy
14,963
Evans, Georgia
I have an autocover also. I still would not want an undersized cell. Come summer with sun, swimmers and whoknowswhat you'll want all the chlorine you need at your fingertips.
Using my oversized cell I was able to run it on a low percentage and my first cell lasted 8+ years. I attribute that to being oversized and under stressed.
Maddie :flower:
sangria
12
Houston, TX
Kim:kim:
I don't have a detailed plan - any suggestions? I'm also wavering on the placement of the stairs and ledge. The side of the garage that faces the pool has a big glass door, so it will sort of act like a pool house. Maybe the ledge should go along there? Thanks for the link to the main drains, those are very nice and I will definitely ask my pool guy about them!
sangria
12
Houston, TX
Maddie :flower:
Thanks for the real life input, I think I will oversize the cell as you and Jim suggested.
Jimrahbe
19,808
Bedford, TX
S,
I am not a fan of stairs that change size as the go down... I like to see stars that are the same width all the way down.
sangria
12
Houston, TX
Please take a couple of pics looking at the house so we can see what you are working with.
I'll try to get some good ones but I am not sure it will help - the garage building has been under construction for a year, so it's pretty wild and will need a new fence and all new landscaping.
sangria
12
Houston, TX
S,
Alternatively I was thinking cascading stairs across the width of the pool, but was afraid of losing swimming length since the pool is so small as it is. I'd like a ledge for my dog to sit on, otherwise I am open.
sangria
12
Houston, TX
The pics WILL help. It will give me something to bounce ideas off of.
Okay, here's the disaster area.
Looking towards the house.
Looking towards the garage structure:
Looking towards the back fence.
As I mentioned, the fencing and landscaping will all be replaced. The tree towards the back right in the last picture will be removed. There is another large pecan (not pictured) which will not be removed.
Thanks for your help!
kimkats
47,360
Tallahassee, FL
That is VERY helpful! I want to make sure I have the correct orientation.
-the cover vault is along the back fence with the end with the steps (guessing this will be the shallow end) it towards the house with the steppers that are light colored with green running through them is right off the sliders for the garage......did I get ti right?
Not that it matters but what is going to be upstairs from the garage? You are going to have to find a way to stop my husband anyone from jumping off the porch into the pool :roll: LOL
sangria
12
Houston, TX
That is exactly correct!
There will be a one bedroom apartment above the garage apartment. It will be for guests for now, as my house was built in the early 1920's and is quite small. I have had the same thought about people jumping from the balcony to the pool. I don't have any kids, but some of my friends are "young at heart" so to speak. I'll be vigilant! There is also a half bath in the garage itself, so no need to really go up there while swimming.
kimkats
47,360
Tallahassee, FL
Okay so I think I have my ideas dialed in now:
-leave the steps where they are good for coming from the house and garage.
-move the benches from the ends. They shorten up the length of the pool too much. You do NOT want anyone to even think about climbing out of the pool by the cover vault.
-put a bench on the side away from the garage. That way when you put a TV under the deck you can sit there and enjoy it.
So what are your thoughts after reading my ideas. If you don't like them that is fine. It will not hurt my feelings!
Kim:kim:
sangria
12
Houston, TX
Kim:kim:
That's a really good thought about the benches, the bench on the cover vault side especially. For tv watching, I'm planning on having a projector face out from the garage towards a projection screen by the fence, so anyone sitting in the garage can also watch. What are your thoughts on steps? I'd like at least one place where the dog can flop/rest if he so chooses. I appreciate you taking the time, since I know from reading that the bling is your sweet spot!
kimkats
47,360
Tallahassee, FL
Oh the asking for BLING will come LOL Got to get the design dialed in first!
-steps/shelf-how big is the dog? If you take that bench out then you can make the top step more of a small shelf and not use up any more of the pool space really. If you want to make it a smidgen bigger you can run the steps out from the shelf by the short/house side making sure to leave a good area to have a wall for swimming laps and such. You could also make the steps run along the long side by the garage but I worry someone will try to walk from the shelf to the bench and "fall" not realizing there is a "break" in the walking surface.
-projector-how long of a throw will that be from the garage to where you are thinking of putting the screen? Make sure you take that into account when you go to buy the projector. That will be SO neat to have!
sangria
12
Houston, TX
He's 60 lbs of love in mutt form. It is quite likely he will refuse to use whatever I build with him in mind, but I want to give him the option! What do you think about four cascading steps across the short/house side?
It's about 18 feet - will make sure I check the throw length.
