New pool owner here been reading alot on TFP.com for a while now in anticipation, PB just finished my pool build over the weekend, filled her up and started up the pumps today. My PB has been excellent in the whole process, but leaves a little to be desired in the detailed answers department to all my questions. So here are a few of my questions, I truly appreciate anyone who replies in advance
1) How can I accurately estimate how many gallons my pool is, its irregular shape with a large Baja ledge, basically a diamond shape as you can see from the picture, shallow end 3.5ft and goes to 5.5ft. 21ft wide/21ft long. If it was a perfect square it would be about 15K gallons, but because its this shape I have no idea how to accurately get closer to true numbers, im assuming its only 10-12K?
2) I was looking at the schedule the PB put together and RPMs, both seemed like overkill and too high based on my reading on your site so far, should I run less often or lower the RPMS to save on electricity bill? Currently he has it running approx 8 hours a day, (5 hours low, 3 hours high)
Low Pool 2300 RPM 6-10am, 7:30pm-8:30pm
High Pool 3000 RPM 10am-12pm, 6pm-7:30pm
Low Spa 2000 RPM
High Spa 2900 RPM
3) Any reasoning behind when to run it? Its cold in Southern California (fontana) and we are not doing any swimming for now.
4) Anything else anyone suggests I do or prep or need to know?
Thank you,
Jacob
14k? Pool/Spa, Pentair Intelliflo VSF, Pentair Quad DE filter, Pentair Mastertemp 400, 5 Globrites (1 spa, 4 pool), 1 aux pump for two water sheers,
Low Spa 2000 RPM
High Spa 2900 RPM
Thank you,
Jacob
