As a fellow Tucsonan and someone with a plaster pool, let me give you some advice - keep a eye on your saturation index but don't try to manage your calcium. Unless you are someone who has a low CH private or community well (there are some folks in Tucson with wells that put out water with a CH of 50ppm) OR your auto fill or hose bib is tied into a water softener, then you get your water from the Tucson Water Dept. and you get the pleasure of water delivered to your home with a CH of 300ppm on average. Tucson has a Class A Pan Evaporation rate of over 90" of water per year and a rainfall of < 10"/year. What this means is that an average depth (6-7 ft), uncovered pool will evaporate
all of its water shock in one year (or less). You will see this reflected in your CH testing as your pool water CH will rise 200-300ppm per year. This is the reality of living in a desert with a pool.
My water is over 4 years old and the CH is currently >1250ppm. I wouldn't be surprised if, by spring time, when I'm ready to dump my water, it's closer to 1500ppm. Even when my water was near 1000ppm, it was still easy to manage and keep scale away. You simply have to focus on your CSI and keep your saturation levels between 0 and -0.3. Since you have an SWG and because rising pH is always an issue around here, you might want to consider adding borates to your pool water at some point (it's not necessary but it can help) as the addition of borates keeps the pH rise under control and it can protect the SWG cell from scaling.
You're doing well and you're on the right track. Just let your pH and TA ride higher during this winter and your CSI will come down. It takes months and year's worth of aggressive water to ruin pool plaster and, as our esteemed expert on plaster (
onBalance) will tell anyone who will listen, water chemistry is rarely, if ever, the cause of plaster issues. Most plaster issues are caused by poor plastering work or simply substandard plaster materials or mixes.
Welcome
