Re: New Pool Build - TX (formerly Red Tape pool dream problem)
Well believe it or not, you were right CusePool, after a "Thanks but that's so far over our budget I don't even know where to begin" email...he did call back and after cutting some things from the design, gets us tantalizingly close to our red line budget
while still keeping our "must haves". Cutting the outdoor kitchen and arbor for a later day. So we are close, but I still want to see if can delete anything else. I have already spotted the Nature 2 and test kit, but thats about it. See anything else that isn't necessary? I am still waiting on my soil analysis from my home builder so I can send it to an independent geotechnical engineer to get their opinion on the designs.
Excavation
1.00 EA Diver Pool 400 Sq. Ft
224.00 SF Diver Pool Over 400 Sq. Ft.
1.00 EA 18" Raised Spa
2.00 HR Hours Of Pre Grade
1.00 EA Stakes And Pegboard
Piers for Pool
12.00 EA Bobcat Helo Piers 7ft Length
12.00 EA Each 5 Ft Helo Pier Extension 5900 psi
12.00 EA Helo Pier Cap
1.00 EA Travel Charge
Pool Steel Cage
118.00 LN 1/2" Steel On 10" Centers
4.00 EA Benches
2.00 EA Tan Decks
1.00 EA Second Skimmer
2.00 EA Deck Dowels
2.00 EA Extra Lights
1.00 EA Diving Pool
1.00 EA Spa Light
1.00 EA Spa Steel Installation
1.00 EA Spa With Double Wall Steel
Pool Plumbing *Going to clarify 2" plumbing
1.00 EA Base Pool W/ Spa 4 Returns, 6 Jets 3" Suction
30.00 LF Plumbing Run To Equip. From Pool
45.00 LF Plumbing Run To Equip. From Spa
25.00 LF Water Feature Pipe Suction From Main Drain
25.00 LF Water Feature Pipe Footage / Return
4.00 EA Jandy Valve For Water Features
2.00 EA Extra Pump Set
45.00 LF Fill Line For Pool Over 10ft
1.00 EA Chlorinator Install
2.00 EA Extra Light Niche / One Stick Brass 1 10ft
3.00 EA Extra Pool / Spa Returns
1.00 EA Equipment Set
Pool Equipment
1.00 EA 3/4 Hp " Cleaner Pump " Hayward
3.00 EA Circulation Pump 3 Hp 230V Hayward Tristar
1.00 EA 525 Sq. Ft. Cartridge Filter Hayward Swimclear
1.00 EA Hayward 400,000 Btu Lx Heater "Propane" Heater/Cupro Nickel Exchanger
2.00 EA Universal Color Logic Led Pool Light W/ 100ft Cord
2.00 EA Universal Color Logic Led Spa Light 100 Ft
1.00 EA 2 H.p. Air Blower Silencer
1.00 EA Nature 2 Dualfusion Mineral Purifier
*Delete*
1.00 EA Pool Pole
1.00 EA 18" Brush
1.00 EA Leaf Rake
1.00 EA 4-1 Test Kit
Delete, already have my TFP
1.00 EA Acid For Deck Wash
1.00 EA Shock For Start Up
1.00 EA Conditioner For Start Up
1.00 EA Pool / Spa Eye Balls / Fittings
1.00 EA Deco Seal / Mastic Joint
1.00 EA Polaris 280 Pool Cleaner
1.00 EA Aqua Logic Controls, Remote, and Antenna
1.00 EA Tax On Pool Equipment 8.25%
16.00 EA Hayward Pro Low Voltage Lighting
1.00 EA Hayward Pro Low Voltage Transformer
1.00 EA I-Connect 4G Automated Hookup Droid Or Iphone
Gunite
75.00 EA Gunite Pool = Yards
1.00 EA Gunite Spa
1.00 EA Raised Spa Spillway
1.00 EA Set Of Steps
4.00 EA Benches
2.00 EA Bathing Shelf
1.00 EA Modern Method Gunite Slide , Planters, And Waterfalls
1.00 EA Gunite For Retaining Walls
Electric
1.00 EA Base Pool Price
1.00 EA Spa Light
1.00 EA Heater
1.00 EA Blower
2.00 EA Extra Pool Light
1.00 EA Pre Bond Pool
2.00 EA Extra Pump For Water Features
2.00 EA Extra Electrical Plug Up To 60 Ft
1.00 EA Automated System
1.00 Low Voltage lighting installation
Tile and Coping
110.00 LN Pool Tile Perimeter
626.00 LF 12" Standard Pool Flagstone Coping
30.00 LF 18" Standard Wide Coping
50.00 SF Spa Facing / Veneer " Raised Spa" Standard
800.00 SF Raised Bond Beam Facing / Veneer Standard
65.00 SF Flagstone Beach Entrance Standard
1.00 EA Spa Trickle Down Spillway
587.00 SF Flag Deck
1.00 EA Over Flow
Swimming Pool Concrete Deck
746.00 SF Exposed Aggregate
208.00 SF Sub Deck = Screeded Sub Base
250.00 LF 4" Drain Pipe
8.00 EA Deck Drains
2.00 EA Down Spouts / Under Ground
1.00 EA Cure And Seal Deck Sealer
Clean and Grade
1.00 EA Clean & Grade
1.00 EA Load Of Top Soil
118.00 LF Color Plaster
1.00 EA Plaster Spa
4.00 EA Benches Plaster
1.00 EA Tanning Benches Plaster
1.00 EA Steps Plaster
1.00 EA Color Goods Package Pool & Spa
Start Up
200.00 LF Mastic Perimeter Pool / Spa
1.00 EA Start Up / Chemical Installation
1.00 EA Acid Wash Deck
Fire Pit
1.00 EA Flagstone Fire Pit With Fire Brick
1.00 EA Risers With Poly Run
1.00 EA Key Assembly And Fire Ring
1.00 EA Lava Rock
1.00 EA Regulator
