- Oct 6, 2020
- 62
- Plaster
- Jandy Truclear / Ei
So one of our PBs broke it down as the rule of "depth plus 1", which is take the depth of the pool plus a foot and that's the distance needed from the house. Generalized, but simple enough.@Erik13 Did they send you the dimensions, you can ask for that. That helped me visualize the space too. Did they say how much space was between the wall and the pool? If it is less than 6 feet then it will cost you more. When we sat down with our builder we wanted ours 5ft from wall and also a sports pool. Something to do with the slope and how close to the house it would be hard to do a sports pool. But also they brought up something that they said many builders might not be doing. I think it was called shoring? When they build so close to the house the sand and dirt can fall from under the house and cause all sorts of issues. They said some builders may not even be discussing this. Since my husband is an engineer he knew what they were talking about. So if we wanted our pool to be 6ft deep, something to do with the slope, we needed to be 5ft from the house wall, and that was another 2K on top of everything else so we decided it was not worth it. The shoring puts boards and stuff to keep the dirt from falling out, so structurly the dirt that is under your home does not move during the pool build. I bring this up so you can discuss with pool builders if in fact your at the 6 or 5 ft from wall. I don't think it is customary or necessary to do if 6ft. Also here is a picture of my pool. It is similar but no spa. Due to our drainage easement it is not a full rectangle. It is going to be 13/14 X 32. First picture is what we thought we were getting with a different builder, second is what we ended up with after we finally figured everything out.
