New Pool Build in Mckinney Texas
Post plaster. Couldn't get a good picture close up. Maybe tomorrow. Acid was first thing in the morning and then fill time!!
Landscape and torches come mid week!!
Inching closer!!
Here is your job for the fill:
-put socks or a cloth over the ends of the hoses. This will protect the new plaster from being scratched/marred and help filter the water some.
-Put the hoses RIGHT on the main drain so there is not "river" of water running down your new plaster. If not main drain put it at the lowest spot in your pool.
-fill the spa last as you do not want to take a chance of it running over yet.
-Do NOT stop the fill water for any reason!!!!!!! Once you start filling keep it going! If you need to slow it down that is okay but not by too much. We had one pool where they stopped the water for the night and it caused a dark ring around their new plaster :(
Kim:kim:
So pool us filled and start up happened today. Landscaping should be tomorrow.
However with two steps forward, there always seems to be one step back.
So when the deck was poured, the jig for the diving board didn't make it. Also, somehow, they poured over the autofill valve. So guess how gets his new concrete cut up already!!? Ugggg
