Got it. So I have the Chlorine version vs the SWG one. I didnt want to worry about the salt corrosion down the road.
Chad,
The Nature2 Fusion appears to come in two models...
The Fusion Soft is a Saltwater Chlorine Generator plus a mineral cartridge..
The Fusion is a Tablet Dispenser plus mineral cartridge..
At this point I am unsure of which one you are getting, but I would not recommend using tablets nor any minerals...
Chad,
Really??? Can you please point us to anyone that you know that has this "Corrosion"???
Equipment notes say Chlorine version. That is where I was confused when that comment first came up because I didnt know it had a SWG one as well.
So maybe I have some bad info. However if there is any trace of salt, doesnt it have an effect on equipment/furniture/rocks etc? Anyways, I would still lean toward chlorine vs swg anyways.
Have you been bonding with it? aka watering it. You can hand water with a hose. Once you get tired of that you can use a sprinkler to do it for you. This helps it cure slower so not as many cracks. Some cracks are normal so no worried there.
Kim![]()
