New Pool Build in Los Angeles
Nov 16, 2024
7
Los Angeles, CA
Hi All,
We broke ground mid-September. So far, so good. We have a great builder! Our backyard was a blank slate. We are now in the process of deciding on the pool finish and decking, landscaping etc. Our plans include a new retaining wall and fire pit seating area. Your comments, tips and advice are welcome!
Reactions: thechem
Well hello there! Welcome to TFP! You have found us just in time to make sure you can start your new pool up the best way possible.
Since you have the shell shot I will start you up with my new pool owners set of links:
Plaster links:Ten Guidelines for Quality Pool Plaster Best one of all
All Plaster Finishes Should Last 20 Years
Not All Color Pigments are Good for Pools How to pick a good color for plaster.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
www.troublefreepool.com
Recommended Pool Chemicals
Which should I buy? TFP's recommended pool chemicals are cheap, easy, and won't unbalance your pool water.
PoolMath
ABC's of Pool Water Chemistry
There are several items things every pool owner should know about swimming pool water. We share details on the basics of Pool Water Chemistry.
Now is also a good time to ask what test kit your PB will be providing so we can fill in any holes.
Kim:kim:
Ensure that the plaster crew removes all the overlap from the tile installation, this will help with a stronger bond under the tile.View attachment 620090
Are you referring to grinding off any thinset on the gunite that squeezes out the bottom of tile installation?
The saddle will help prevent pipe breaking from forces (leaning on) pushing downward, this will give the plumbing pipe more stability.
It appears in the picture that the JANDY valve face is tight to the wall and may become a problem when needing to replace the valve spring/flap.
By adding a 90 to each air pipe it will in turn have the openings facing downward and less chance of objects being inserted into the open pipe.
Also, a pipe extension can be added to the filter drain plug to make access easier for draining the tank.
