Yes, astronomical, thank you. Prior to beginning SLAM (which I hope we can finish by tomorrow!), I had been running pump at night daily for 8 hours at 3000rpm bc was told all water needs to circulate at least once. Are you suggesting I might lower RPM for same 8 hours per day or what combo of hours/rpm do you think is right?
OK. A suction cleaner attaches to a dedicated line or in the skimmer and uses a vacuum device powered by the pool pump to clean the pool. So I assume you do not have one!
Then your pump rpm only needs to run high enough to close the flow switch on your SWCG.
sorry, I'm a real novice. When you say "enough to close flow switch on SWCG" what does that mean or how do I know? In other words, if I run pump at say 1500rpm and Hayward Aquarite SWCG is turned on, once the "generating" light is on, then is that good enough? or am I looking for something else?
A SWCG must not be allowed to generate chlorine when the pump is not running or it can explode. The primary safety device to to remove the power to the SWCG when the pump is not running. I hope yours is set up that way. The SWCG must be on a timer to run when the pump is running or have some other method (automation, current sensor, etc) to only allow power to be sent to the SWCG when the pump is running.
The SWCG has a flow switch which is a secondary safety device. So you need to run the pump at a rpm such that the flow switch 'closes' and turns on the generation of chlorine. So if the light that says the SWCG is generating is on, that is a sufficient rpm to run the pump at.
Hi, just checked again. FC at 21. Added 100oz of 10%. Brushed pool bottom. pool cover still open. Pump running at 1300rpm. Will check again in 2hrs.
Sorry to ask again, wife asked me to be cautious. Can kids swim if FC is 28 or lower?
You originally reported a CYA of 65, that is why we said to use 70 for CYA and 28 ppm for SLAM level FC. If your CYA is higher, then a higher FC is needed and may be why this is taking longer than I thought for a pool with CC but no visible algae.
Have you brushed or vacuumed any dead algae?
You can add the water.
As long as the FC is at or below the SLAM level FC based on CYA as shown in [FC/CYA][/FC/CYA] they can swim.
No need to run the pump any faster.
After adding chlorine it is OK to swim after about 15 minutes with pump on.
Do you have a light in the pool? If so, do you know how to take the light out of the niche? We have found members having algae inside them that mess up a SLAM process something terrible. Also the underside of your cover.
Well, that's interesting. I do have a light that's very rarely used but I do not know how to take it out. Don't you need to lower water level below the light level or the whole thing will leak?
I have not checked underside of cover. It's an auto cover so I can't lift it out of its place. Should I just check for green/yellow/black on the underside?
The light, is it a large one? Does it have a metal rim around it?
If it is, there should be a screw at the top. You remove that screw and the ring swings down or comes off and the light can be taken to the deck as there is extra cord in the conduit.
