- May 3, 2014
- 58,832
- Fiberglass
- Pentair Intellichlor IC-40
You started this thread with a CC of 2.5 I believe. That is very high and is a result of chlorine consuming organics in your water. You SLAM to eradicate those organics.
After you have maintained SLAM level FC for a couple days, do a Overnight Chlorine Loss Test to see if you have successfully eliminated the organics.
Visible algae means your pool is overwhelmed. Catching it before it gets to that point is good as your SLAM should go quickly.
