Hi. Was wondering how often you find yourself adding 10 min (with hose) of water to pool? Even though we have an auto cover, seems like I’m adding once per week.
Also, if I don’t use the pool for 2-3 days, cover is on, and SWCG is running. At night, wouldn’t that increase the FC or not necessarily?
There is some evaporation. You have less that I get. But some is not unusual in your climate.
You can lower your SWCG setting as you see your FC increase over the level you want. It is true with it covered there should be minimal FC loss. Are you testing your FC every other day or so?
I’m testing my FC daily and it’s consistently at 10. Should I test every other day?
I was wondering if the pool is not used for a few days but SWCG still running at night if that will increase the FC.
Sorry, accidentally posted twice. FC has fluctuated a bit 10-12 but not much. Yes, using Taylor kit w GAS-DPD and Speedstir.
So my question is if FC is at 10, but we don’t use the pool every day and cover is on, should I reduce the SWCG?
Good morning. Probably a silly question but worth asking. We’re finally getting some rain in SoCal. We have auto cover. If my pool water level is a bit low, any harm in letting it rain a bit directly into pool? Shame to let all that water waste. Probably changes PH level. What do you think?
For winter I reduced run time of my pump to 6hrs/night at the low rpm you previously recommended. Do I even need that or can I run 3-4 times per week instead?
Quick question... For winter I reduced run time of my pump to 6hrs/night at the low rpm you previously recommended. Do I even need that or can I run 3-4 times per week instead?
