Hi all,
I got my new hot tub (467 gal) hooked up the other day and did a 50ppm Chlorine shock and Ahh-some and got some nasty out. Drained and refilled. The day was shot so I let it sit overnight and left it running.
Next day water at 99 deg followed to 3-step bromine method here:
But started with the water balancing instructions from here:
It didn’t go as I expected...I have the Taylor K-2106
Calcium Hardness read at 100 I raised it to 130.
TA read at 110 and PH 8+ so I started with aeration (30 min while I ran to the store for Muriatic Acid) and then added 2 oz per the table for reducing PH to 7. 30 min aeration later I needed another 2 oz, next cycle 1.5 oz, next cycle 1 oz, next cycle 0.5 oz. 2.5+ hours later after all those cycles PH was always 8+ off the scale when I check 30 min after. Since this wasn’t matching with the instructions for about an hour to lower TA by 100 (I only needed lower by 60) I tested TA and it was 20. Why didn’t my water stop with PH around 7.6 and TA 50 like instructions stated it should? With it getting dark I added Baking soda to what should bring TA to 50 and another .5 oz of Muriatic Acid to reduce the PH from 8 to hopefully around 7-7.2 (I stopped testing) and finished out the instructions.
I added 50ppm Borates via Boric Acid (19oz vol).
Added 30ppm Sodium Bromide
I used Pool Math set current FC to 0 and Target 10 and shocked with 10 oz 6% bleach. Is that the right way to do that?
The water turned a green tint. Is that normal?
Immediately after, I added the floater set to 2 with 4 pucks. And after a few minutes the water turned a blue tint???
Why did my PH never level out?
What’s with the color tints? I dumped the test samples on the ground but rinsed in the spa, is that bad? Did that cause the color tints?
How do I measure FC to know when a shock is done and it’s safe to enter the water with the K-2106?
I’m going to retest everything when I get home from work but any advice would be helpful.
Thanks!
How do I use Bromine in my spa (or pool)?
Originally Posted by waterbear There is a lot of misinformation on the proper way to use Bromine so I hope this primer is helpful. First, you need to establish a bromide reserve in the water. Bromine tablets can do it by themselves but it can take literally weeks until enough dissolves. Some...
www.troublefreepool.com
How do I use Chlorine in my Spa (or pool)?
If you have a question about any information within this Sticky, please start a new thread for yourself where you will receive very quick responses to your specific questions. Thank you! Introduction There are two main things to consider when maintaining your hot tub water, Water Balance and...
Thanks!
