So, for all pools with IntelliFlo pumps, you recommend 3" plumbing?
In any case, the skimmer's design flow rate won't support the Intelliflo at full speed.
Also, the flow is distributed over 2 skimmers and the main drain.
The Intelliflo can be password protected to keep unauthorized persons from reprogramming it or you can get the I1 if it's a big concern.
I seriously doubt that an inspector would require 3" plumbing on this pool.
If you have 140 gpm coming out of 1/2" eyeballs, that seems like the velocity would be dangerous unless you have a bunch of eyeballs but then they wouldn't provide sufficient head loss to matter.
1 eyeball = 230 ft/sec. (I'm pretty sure that's what they use on water jets that cut steel lol).
2 eyeballs = 115 ft/sec.
4 eyeballs = 57 ft/sec exit velocity.
