BattleOfYakima
Side note: The garage is a no muriatic acid allowed zone, no exceptions.
Well, upon further research, the expert consensus is NO to long-term trichlor storage in the garage due to corrosion of metals. Corrosion on golf clubs has been observed in less than 3 years. I apologize for the last post, editing it now. Just get a plastic cabinet or big rubber tote and store in shade, careful when opening due to fume build up. Or just sell them on craigslist. Or return.
Chlorine Drop test - If you need to......1) measure Chlorine levels accurately or 2) higher than 5ppm or 3) test for Combined Chloramines…perform the Chlorine Drop Test. (FAS/DPD)
1. Rinse and fill the “Chlorine only” graduated cylinder to the 10mL mark
2. Add ONE heaping scoop of the R-870 powder and swirl to mix. (It may not all dissolve….don’t worry) The solution will turn pink. (unless you have no chlorine)
3. Next, carefully add R-871 solution one drop at a time. Count each drop and swirl until the solution turns back to clear. Multiply the number of drops you added times .5 (14 drops X .5 = 7ppm)
4. Record your results as FC (free chlorine)
5. To test for Combined Chloramines, add 5 drops of R-0003 to the solution and swirl. If it remains clear, you have no CC’s. If it returns back to pink, add R-0871 as before, counting and swirling between each drop. Once the solution returns clear, multiply the added drops times .5 again…..this will be your CC reading. Record it. The total of FC and CC should be recorded as TC (total chlorine)
You can do anything you set your mind to - decide to get good and don't negotiate about it! You got this!I was never good with reading directions
Samples often don't represent the entire pool unless the water has been circulating for 20-30 minutes, depending on circulation of the given pool. When in doubt, 30mins, and always trust results of a well circulated pool.TA is 50 less today, is that because the pump wasn't running yesterday before I took the sample??
