- Apr 23, 2017
- 2,400
- Plaster
- Hayward Aqua Rite (T-15)
Add the 7 bags and then measure salt. It's always easier to add more salt to get level up than to drain and add water to get salt level down
I'm still messing with my ic40 trying to dial in the right numbers so just be patient and prepared to try all sorts of things.... longer pump run times, different times of day, adjustment on he percentage etc
You have my number so feel free to reach out and I might be able to save you some heartaches I experienced lol
Jim,
Pool deck question here. It looks like you went with pavers over a cement pad? Or am I just not seeing things right? If so, just curious why you went that route as opposed to the usual packed stone/tamped sand base? I'm getting ready to renovate our pool that currently has a concrete deck that will be pulled up and replaced with pavers hence my question. I'm in Delaware not too far away from NE PA, so still considered midatlantic area.
im on concrete cause it is the only way my dad's buddy and my buddy will bid jobs. In thier experience it's the only way to go. If done right they will never ever move. I have seen 20 year old paver jobs they have done that look like the day hey did them. Ya it's a lot more money but it's the only way to go we believe.
Im on a 4 inch pour with gavel, mesh and rebar just like sidewalks. We did all slopes on the scratch coat so pavers just followed grade.
Interesting approach for sure. If the underlying pad shifts, that would be problematic as you would have to pull up the pavers and replace the pad in entirety, but that's about the only issue I could see with that approach though. Are you laying down the pavers yourself?
Actually, now that I think about it, it's always cheaper to pour cement pads vs pavers as a general rule. I could have the cement pads poured and then perform the paver installs myself over the pads. I bet taking this approach wouldn't be any more expensive than having pavers professionally installed outright. You got me thinking now! [emoji1]
In a properly chlorinated pool phosphates and nitrates are all but irrelevant.
Pentair subscribes to the standard industry practices for chemical levels which does not acknowledge the FC/CYA relationship.
I keep my CYA at 100 and FC around 8-10...
What's wrong with your cell?
