- Jun 27, 2008
- 6
Hi all, Please advise
Should I "SLAM" the pool with Liquid or use none CL oxidizer (Potassium monopersulphate) which I bought? I dont want to bleach a new $5000 liner. I called the Lathan liners and asked how high can the CL go to below bleaching. They wouldn't answer the question.
New liner installed July 14th, New water from town supply. Water chemistry was ok until this weekend. Im using Chlorine feeder with stablized pucks but I think it had an air lock or is clogged and CL dropped too low. Had heavy rains. Went away for the weekend and came back home and water is cloudy (whiteish not green) No algee visible.
Checked FC and was zero with test strips. Last night I shocked with 4 liters liquid CL (10% to12%) waited 30 mins and retested still 0 FC. Added another 3-4 liters (what I had left). Checked test strip again 15 mins later 0 FC but 5CC
Today it tested water and had pool store test as well. My tests were with with a brand new Taylor K1005 and DPD FAS kit
Outdoor vinyl pool 77000 liters (not salt) - No heat added, No cover, 75% Sun exposure
Pool has 500ml of 60 % poly-quat added July 21st
6PM
Pool store tests with Waterlink spin touch machine
FC - 0.36 - (My test FAS shows FC 1.1)
CC - 2.45 - (My test FAS shows CC 2.8)
PH - 7.7 - (My test 7.5 to 7.7)
HD - 102ppm
Alka - 96 (My test 100-110)
CYA - 44 - (My test strips show 30 - 50)
Copper - 0
Iron - 0.1
Phos - 37ppm
Temp - 78F
Update @ 10:45PM retested and decided SLAM. Added 7700ml CL (10-12% liquid pool store stuff)
FC 1.8 (FAS) - Start
CC 2.0 - Start
11:40PM
FC 4.5 (FAS)
CC 0.5 or less (10ml sample had hint of pink before starting adding #R003. Added 1 drop and started stirrer. Made it clear (opposite effect) but good regardless)
Still cloudy but see in morning....
7 days later... for those who care...
Pools FC was held at 2 to 4ppm each dayand tests showed 0 CC all days via DPD tests. Added Liquid as needed at night
Day 2 added 1/2 cup PE powered to sand filter for 1 PSI increase
Cloudiness cleared up 100% buy morning of day 3.
Pool is normal now.
6PM
HD - 102ppm
Copper - 0
Iron - 0.1
Phos - 37ppm
Temp - 78F
CC 2.0 - Start
11:40PM
FC 4.5 (FAS)
Pool is normal now.
