As a total beginner, this forum has been an invaluable resource in trying to quickly get a grasp on this large project we're about to undertake. Huge thanks to everyone here!
Basics:
Here are the line items from the PB's propsoal. It's all open to discussion/change, but will attempt to minimize change where possible.
1 x Pool skimmer
1 x Automatic water leveling devise.
1 x Split main drain per VGB rules.
6 x pool returns.
1 x cleaner return line.
1 x split heat suction in spa per VGB rules.
1 x Split spa jet suction per VGB rules.
8 x Spa jet return lines
4 x Spa heat returns.
1 x Automatc pool cover from Pool Covers Inc.
1 x Pentair Intellitouch load center wo/salt
1 x Pentair I7+3 pool/spa Intellitouch Personality kit
1 x Pentair Intellitouch interior controller
2 x Pentair Intelliflo XF variable speed pumps
1 x Pentair Boostrite booster pump
1 x Pentair CCP 520 cartridge filter
1 x Jandy Hi E 2 400K BTU heater
1 x Pentair Intellichem PH/ORP system wo/pumps
1 x 15 Gallon Stenner tank w/pump
1 x Pentair CO2 kit for Intellichem
1 x Clearwater Tech Apex III ozone system
1 x Clearwater Tech 30 gallon degas tank
1 x Clearwater Tech VAS8 off gas valve
1 x Clearwater Tech OCD 11 Ozone Destruct
1 x Paramount 2 lamp Ultra UV
9 x Pentair Globrite white only LED pool lights
1 x Polaris 280 pool cleaner
My main concerns at this point are moving to SWG, need for ozone, need for UV.
The PB is very anit-salt. Automatic cover manufacturers are anti-salt. And we're using limestone, although will be sealed. Despite these facts I want to go with SWG. As a compromise, I'd like to use the following low-salt SWG, which can run on 1500ppm of salt:
Hayward AquaRite AQR XL Low Salt W/ 30K Cell.
Now for some questions:
1. This low-salt SWG isn't available in US market, but I can purchase online from Canada. Any reason this is bad idea?
2. If the 30K cell isn't sufficient, any reason I can't just add a second cell in series with the first?
3. Will the Pentair automation work with multiple AquaRites?
4. Or ditch second cell and keep the Stenner as backup chlorinator for high-demand times?
5. Any thoughts on using CO2 for pH control in this environment?
6. Sounds like switching to SWG will make ORP useless, if it wasn't already?
I know the consensus here is to ditch the Ozone and UV. But..
7. Given the pool will mostly be covered, could UV be beneficial?
8. With pool only, sounds like ozone is useless, but what about with spa?
9. Any other comments on this build?
Thanks for reading and any input you might have on this!
Basics:
- New build
- 12' x 75' 30K gallon outdoor in-ground pool
- 8' x 5' 1K gallon integrated spillover spa
- Pool and spa glass tiled
- Automatic cover
- Hoping to operate the pool/spa year round.
1 x Pool skimmer
6 x pool returns.
