we have to move ours too. first quote was for $2017. 2nd quote was $1500.
We are being charged $14/ft but need to move 186 ft, so it is a large move.
I see deck jets on the one artist rendering. Be forewarned, they are pretty noisy. We put two in our pool and have used them twice for a couple minutes each. It is not pleasant if a group is on the patio and they are running.
Take care.
Just got the bad news today that my electrical feed to my house will have to be moved. $2850 to relocate it away from my proposed pool locations.
I just had ours rerouted in Katy for $1800 for approx 190 foot wire run. Your quote is way high given we have a huge yard and run to the meter. Let me know if you want the name of our guy.Just got the bad news today that my electrical feed to my house will have to be moved. $2850 to relocate it away from my proposed pool locations.
Any comments regarding my equipment? Everything look okay for the size of my pool?
vertical pool returns
Not sure what that means. Bubblers?
You do know you are paying for an in-line chlorinator with a SWCG? You do NOT need the chlorinator.
Take care
Why not use bleach for the first month or so?
Better to keep a handle on your pool water chemistry than use pucks that you never sure if they are dissolving, have to monitor CYA constantly to assure you have enough FC, etc.
Someone clearly didn't think that through when they mounted the pump to the slab that close to the A/C unit.
Is it actually touching? I personally wouldn't worry about it from an airflow standpoint, but if it's touching it seems like it might rub through the pipe? Perhaps that's a long shot.
Dan
