I just bought a new Jandy/Zodiac spa side remote switch (4 button 7443) to replace the old one that failed years ago (sun deterioration followed by a short, presumably). Before fishing the line through, I connected the terminal (wired the same as the existing one) and plugged in to my controller (Aqualink RS4 - from around 2001, 6522 Rev 1). Hit reset. Check switch assignments on RS4: 1 = spa, 2 = heat, 3 = blower, 4 = light.
When I tested the buttons, 1, 2 and 4 all work, but 3 does not (and the red LED on the remote is always on). I tried swapping assignments for 3 and 4 and sure enough, button 4 turned the blower on and button 3 did nothing. So I got a replacement from vendor. Same result. So 2 brand new remotes, both with button 3 not working. I checked to make sure all lockouts were not enabled, still button 3 does nothing. (Also tried assigning it to other functions - same result).
Is my controller bad or just too old? Or is it something else?
Thanks.
Thanks.
