I've seen previous same situations in the thread but have yet to nail down why mine won't turn on, and am pretty much at the end of my troubleshooting list and humbly come for some assistance from you guys.
When sending a pump start signal from the board, you can hear a click and the light above the service button for the pump turns on (or in the app the icon changes) but the pump doesn't start running.
Pump: Jandy Model No: VSFHP165AUT
Wired to a brand new Aqualink RS: RS-P4
- I have connectivity to the system from the app through the wireless access - so that is set up. (Also having done that I now have access to the manual buttons in Service mode in the Aqualink box)
- There is 240V power at the pump when the pump switch turns on from the box, and it goes away when the pump switch is turned off
- I saw something in a previous dead thread about having to set up the VSP pump in the app settings re: speeds etc. and did that to the best of my ability (and pressed "save" before leaving that page in the app). Wondering if there is something unique I am missing there?
- I also tried to set up a schedule (1:00pm - 12:59pm to basically just have it running 24/7 just to get this figured out) in case it was getting the "switch" to turn on, but was not due to a schedule situation. The same issue of it not turning on occurs whether switching it on and off from the app, or from the panel in Service mode - so I don't "think" it's a schedule problem
- The 5 position DIP switch in the pump is set to 1-4 Off and 5 On (as was in the manual assuming I was using the right settings for this particular pump which was not super clear...)
