Hello everyone,
My wife and I just finished installing an Intex Ultra XTR 16x48 pool.
Despite our best efforts to level the ground which required digging down almost 7 inches on one end (we had no idea our yard was so uneven) and then adding a layer of sand to fine tune everything, the water level is uneven by slightly under a 1/2 inch.
We also tried to keep the legs straight as it was filling but as things have settled, the bottom of a few have moved out slightly and some inward. The ones that moved inward, I was able to pull out to make them level but I am unable to straighten the ones that moved out.
I am fairly sure I know where I messed up... I placed the legs/feet on top of the sand when I now know that they should have been placed directly to the soil. I have seen arguments about whether or not to use pavers so i'm still unsure if they're necessary or not. Wish I had done more research before hand...
My first question is - How bad did I mess up or am I just being overly worried? I've read that metal frame pools are ok up to 2 inches uneven and I'm sitting at around a 1/2" so... I hope others with more knowledge can chime in and let me know what needs to be done if anything to correct the situation.
Another question is in regards to adding a through wall skimmer. I see that many have done it but something in my head is telling me that cutting a hole in the liner is just begging for trouble as it adds weak points that can fail and cause the liner to tear. Am I wrong?
