Hi All,
We have a pool company coming out this weekend to install our new pump and I'm looking for some suggestions on the configurations. The attached images are of the pool and the plumbing as it is today. Our goal here is to move all of the equipment to one side, re-plumb everything to get the Spa returns working and save some money with the new pump. I have a few questions though before we get started and I'm hoping you all can help. (Yes, I already know the pump is overkill.)
The Pool
Pool Info
Cheers
The Pool
Pool Info
- Dimensions 26' x 13' and average depth of 4.5'
- Water = 11,407.5 gallons
- Ideal GPH = 1425.94
- Ideal GPM = 23.765
- Between 60-70' of 2" pipe between the pool and the pump
- 2 standard returns (in corners)
- 1 suction skimmer
- 2 drains that join into suction 1 pipe
- 5 Waterway return Spa Jets (at one end & capped off currently)
- 2 small waterfall features on the side that flow from 1 return
- Pentair IntelliFlo Variable Speed Pump 3 HP
- Min Speed (450-1700 RPM) - Default: 450 RPM
- Max Speed (1900-3450 RPM) - Default: 3450 RPM
- Hayward Pro Series S210T Sand Filter - 50
- 50 PSI Max - 80 GPM Max w/2" pipe
- Pentair Mastertemp 200 Heater
- 20 GPM Min - 120 GPM Max
1. Plumbing
- What would be the ideal way to plumb this setup? The Spa returns are currently capped, we are looking forward to opening them. I was thinking something like this: Plumbing Example but the pool company says I do not need a Spa Make-up or a Check Valve. They also want to use all ball valves instead of any diverter valves.
- If I don't need a Spa Make-up and use diverter valves; I thought something like the following image might work?
2. Pump Settings
- I've read a lot about how a single turnover is a rule of thumb but also kind of a myth. For piece of mind though, I know how to find what a single turn over should be in GPM but no idea how to tell how what the RPM's should be on the pump to achieve that?
- What is the best way to decide what the settings should be at for running the Spa?
- What is the best way to decide what the settings should be at for running the Spa and waterfalls?
- Should we be planning to skim and run features at the same time?
- Can our setup even handle everything running at the same time?
Cheers
