Hi All,
I am about 75% through a new inground pool install. So far, things have gone much smoother than I expected. Now that I jinxed myself, my electrician is going to tackle installing the EasyTouch 8 with the IC60 Salt generator. I am hoping to have everything planned out so we are not trying to figure out on the fly the correct thing to do.
Can an easytouch expert help me out here?
Here is my equipment List:
EasyTouch 8 with IC60 salt + ScreenLogic kit
2 hp Max-E-Pro pump for the SPA
3hp Pentair/Starite vs+vsf pump for the pool - I have the special cable that the pool guys nearly threw out on me :-0
Polaris Air bubbler for the spa
LED Pool light
I've tried reading the easytouch install guide - which drove me straight to here LOL.
What breaker sizes should I be using, how many? Is order important? I thought I read the 1st breaker needs to be 15 amp and is wired to the powersupply of the easytouch
Once I have the breakers, then I have to map the breakers to relays, any input on that? I would think the spa pump and air bubbler would be on separate relays but configured for 'SPA', correct?
Relay 1 - main pump & Salt - these get wired together
Relay 2 - spa pump (can the air bubbler be wired here as well)
Next Relay - pool light (or air bubbler)
am I one the right track here? I don't have a heater yet - that will be a spring time purchase. That looks to be fairly straight forward
Once again, thank you all for your expert advice & willingness to take the time to help us newbies out
LED Pool light
