New IC40. Installed and not working
Ibolivarc
Active member
Sep 7, 2020
28
SAnDiego
Hi just changed my IC40. Old one was producing to many errors. But know FLOW is a problem (in red) and this wasn’t a problem with the old cell.
any idea what it might be? Faulty cell?
Jimrahbe
19,832
Bedford, TX
I,
Either you have good flow or you don't...
If you have good flow out of your pool returns, then the cell or more likely the flow switch is bad.
If you have poor, or weak, flow out of your pool returns, then the most likely cause it that your filter is dirty.
I suppose you could have the cell in backwards... We have seen cases where the cell was originally installed backwards, and then the installer turned the flow switch backwards, to make it work. :(
As long as the flow light is Red, nothing else will work.
Ibolivarc
Active member
Sep 7, 2020
28
SAnDiego
I,
Jim. Thanks For the reply
The flow is no good. Red light since installed.
The cell was installed same as the old one. So it’s not about cell is backwards.
the question here is with its was working with old and not with new ?
Ibolivarc
Active member
Sep 7, 2020
28
SAnDiego
Just changed my ic40 cell. Old one was having issues. When changed with new one, flow is now the problem. What can it be? Dirty filter o bad cell despite new?
How can I backwash my filter
Ibolivarc
Active member
Sep 7, 2020
28
SAnDiego
It appears you have a DE filter. Have you never backwashed it before? What type of valve do you have on the filter?
Yes DE filter. Seems last owner Backwashed on may 2020. Here are some pictures. Really going insane here
Jimrahbe
19,832
Bedford, TX
I,
It sure looks like your cell is in backward to me.. But then I can't see all the plumbing because everything is too close up.
Seems to me that water should flow up through the cell and then go left to your pool returns or right to your spa. ????
Ibolivarc
Active member
Sep 7, 2020
28
SAnDiego
I,
the cell is in the right position Jim. That’s the way they installed it. Want any more picture?
the issue is that everything was working fine but the cell. That’s why I changed it. And when changed, then the flow presented a problem.
JamesW
21,547
You need to break down the filter and clean it properly. Backwashing doesn't really work that well.
More pictures of everything would be helpful.
Check the baskets in the pumps to make sure that they are clean.
What is the filter pressure?
Can you feel any actual water flow from the returns?
Remove the cell and check for debris.
Check the screen on the in-floor cleaning valve.
Jimrahbe
19,832
Bedford, TX
I,
Tell me what the valve just above the cell does??
Show me a pic of the cell showing the input and output pipes and where they go..
Do you still have the old cell? If so, remove the cover over the flow switch and show us some pics.. I suspect that the flow switch in your old cell was put in backwards so that your old cell would work.
Ibolivarc
Active member
Sep 7, 2020
28
SAnDiego
I,
Jimrahbe
19,832
Bedford, TX
I,
Thanks for the pics.. It makes it clear that I was wrong and the cell is installed correctly... Too bad, as that would have been an easy fix.. :mrgreen:
mknauss
33,894
Laughlin, NV
Technically, Pentair states when the IC is installed vertically, it should be on the upflow section. That is to ensure the flow switch does not fail closed and allow the cell to generate without water flow.
