Hi this forum has been helpful, appreciate.
I read the sticky note for hot tubs and 2-step, 3 step Bromine, but confused.
Spa is 550 gallon
Has ozonator
103 deg F
Measured with K-2106 (just got) today
Total bromide 21 PPM (high I know)
pH 8.0 (high reading maybe due to high bromide?)
TA 75
CH 250
0.5 saturation index
Spa store sold me Spa Frog floater with bromine and mineral cartridge, frog test strips and Frog Spa Starter.
Filled with softened water and added liquid calcium, 25 oz, gradually per hot tub store.
Followed Spa frog instructions - once warm, added Spa frog starter packet for up to 600 gallon spa, probably dichlor powder?
Then put in floater with mineral (yellow) at 6 and bromine at 4 per spa store recommend.
Oxidizer they sold me is Serena Spa Oxy Blast, Sodium Peroxydisulfate 50%, instructed to add two capfuls a week.
Added a capful after excessive use, 5 ppl a couple times a day. So about a capful a day. On day 7...
After a couple days measuring zero "free bromine" on frog test strips, I bumped spa frog bromine cartridge to setting 6, and added 1 ounce Spa Choice Bromine Booster (99% Sodium Bromide), it's a white powder. Maybe that was a bad move. I wanted to see "free bromine" register on the frog test strips, recommended range is 1-2 ppm.
We have been using spa a lot, 1 week in, but obviously I'm not doing it right.
Removed the floater for now, as bromine seems really high. My fault I'm sure.
Any recommendations appreciated. Can drain and refill, if needed.
Spa is 550 gallon
Has ozonator
103 deg F
TA 75
CH 250
