Hello,
We are purchasing a house with what I would call basically an inground pool. It is roughly 15x32 oval and has a deep end. The pool is roughly 1-2 ft above grade at the rim with a deck around it. The liner was about 4 yrs old. The problem is the pool was never closed propertly and all the pipes froze and there was a low return which cracked the ball valve in the filter area and basically drained the pool sometime between this Jan-March. I was able to plug the line. The deep end still has water upto about 2’ below the shallow end. The pool has a staircase in the shallow end and the liner appears to have shrunk and seems too small for the pool on one side. I called the pool guy who installed the liner and he said the pool is beyond repair and would need a new liner. The liner is not ripped yet but he said if I try to refill it it will rip. Is there no way to save the liner ? We cannot afford a new liner so we would have to bulldoze it. I was wondering if we putnthe shop vacs behind it and flilled it a little each day and let it strech back out ? Or is it a lost cause?
