R
ralphsyv
Too late.if he hasn't already stop him Chlorine is all you need
Actually, I think the OTO test kit was completely thrown off when they added Silvercide. I feel like a dumbass now because I called the pool service company to complain and argued with the owner for 30 minutes.It's possible that the algae you see is burning off your free chlorine faster than they are adding it. If the CYA is indeed 25, then 40 is more in line for the guidelines. With a low CYA it's possible the sun is burning off the free chlorine faster than they are adding it as well, or a combination of both. Here are the basics for that. It probably wouldn't hurt in the meantime to add some liquid chlorine (bleach) to try to keep your levels up.
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.www.troublefreepool.com
They are adding cyanic acid next week and that should get CYA up to at least 40.
So far I'm just testing to understand what's going on. I'm getting a new test kit on Saturday. I believe the cya is low right now at 25 and ideal is around 40. They are adding cyanuric acid next week on Tuesday to get it at the right level.Don't let the do that, as that will just cost you more $ in chlorine when you SLAM. What is stopping you from firing them?
They're not going to be taking care of the black algae. Their solution was "Have our guy dump in some silver and it will go away. Trust us."If it were me, I'd tell them to take care of the algae and to wait until early spring to bring up the CYA.
Black 'Algae' is not really an algae. It is a bacteria.They're not going to be taking care of the black algae.
Thanks for pointing that out. That's why dumping in silver is not going to make it magically go away. I've been brushing them. They actually look like rings or mini doughnuts about dime-size or smaller.Black 'Algae' is not really an algae. It is a bacteria.
"They're single-celled organisms called cyanobacteria that can be black or dark blue-green. Black algae are so tough to kill because they're an encapsulated bacteria – they have a hard outer shell that makes them able to weather various harsh conditions."
Read Black Algae - Trouble Free Pool
