n240sxguy
Sounds like you've got it all figured out. I think Patrick was just saying if you wanted to raise the CH a little, you could use the cal-hypo. Mine stays around 250. It'll be a little higher at the end of the season because I'm adding more with my fill water, and it stays behind when the water evaporates out of the pool. After all the spring rains and having to dump water, it goes down because the rain water has diluted it. Once you get a better feel of the pool, you'll know how much bleach to add each time without having to calculate it as much. It's best not to let it go below the minimum so algae doesn't have a chance to even start growing. At a CYA of 40 the minimum is 3 and the target is 5. That's what you should shoot for. You could target 1-2 ppm higher fc and let it drift down and still be above the minimum without any adverse effects. My cya is 50 so my minimum is 4 and target is 6. Since its too cold to get in my pool right now I raise it up to 7-8 so I don't have to worry about it for a few days if I don't get a chance to check on it. That's nowhere near slam levels, and still low enough that the ph test doesn't get affected by it.
