We finally had our pool plastered Tuesday and Wednesday started with chemicals (muriatic acid 1/2 gallon) and brushing.
today is the first day to add chlorine and I did add 1 puck per skimmer like instructed by the pool company then I realized that the skimmer may not be the best place for it so bought a floating chlorine holder and went home to also check that the heater was on bypass and it was not. I have 2 questions:
1. should chlorine pucks go in skimmer during startup: the pump is running 24/7 and we have 2 skimmers (1 puck in each every few days) or should I place them in the floating chlorine holder? (I figure + of skimmer is quicker dissolving and - is wear/tear on skimmer area and pump/filter)
2. should I bypass the Heat Pump: (it does have a check valve and a bypass) I decided to bypass it today but then realized that maybe they left flow to it on for a reason?
thanks,
Mike
thanks,
Mike
