- Jul 22, 2018
- 39
- Plaster
- Pentair iChlor 30
Hi all,
I have searched around here and found how heavily favorable the Raypak gas heater is. I was all set on my decision, until my installer recommended the Jandy JXI. He has experience installing both, but is a Jandy preferred installer so can double the warranty on parts and labor to 2 years vs the 1 for Raypak. He did say both units are really solid heaters.
My only reservations about the JXI are
A) limited time on market so no real long-term reliability data yet.
B) It is induced draft so has a blower motor and 1 more part to fail.
My heater is in an L shaped corner of two walls and I was told that this "could" cause turbulent air which the Raypak may struggle with.
I do like the very compact dimensions of the Jandy, since my office window looks right at my pool equipment. The Jandy would be below the sight line but the Raypak would stick up considerably higher. This would only be icing on the cake though. Not enough impact to sway me from a good heater to a bad for aesthetics.
Either unit will cost me the exact same amount installed and would be 260/266 BTU for the Jandy & Raypak respectively.
Thoughts?
Thanks!
Thoughts?
Thanks!
