Here are first set of test results:
FC: 2
CC: 0-0.25 (very faint pink, totally colorless with 1 drop)
PH: 7.7
TA: 210
CH: 150
CYA: <20 (not cloudy at all on test)
For the most part I’m not trying to interfere too my much, since my builder said they would handle startup and manage chemicals until pool school. That being said, I want to keep an eye on things and definitely don’t want to let them do anything I will have to pay for later. I’m mainly trying to use this time to learn the testing process and I’m hoping they will let me compare notes with their readings to see if I’m seeing the same numbers. Right now the system they installed is a Frog (I’ve read all the posts on this so likely won’t use it going forward, maybe just the Chlorine pack if I’m out of town).
A couple questions I have for drop tests. Do you count the last drop when a substantial color change happens, or the next drop when the color completely changes? For instance when I do the CC test, the water is barely pink, but if I add a drop I can still detect a slight change in color. Should I put that down as 0.5, consider it near or at 0, or basically say 0.25? From what I can see on the FC test, the change even at 0.5 ppm steps from pink to clear is pretty noticeable. Sorry if I’m being a little OCD here, I just know pretty much any CC is bad.
FC: 2
PH: 7.7
TA: 210
CH: 150
