Hi! We just had first water test done, at a pool store, as I wait for my TF-pro salt kit to arrive. Complete newbies to owning a pool, and still surrounded by dirt so the SWG isn’t even on yet. No salt has been added, shock added once.
Here are the readings and their recommendations. Would love any advice as I get going! How bad is this, should I be doing daily tests at the store, etc.
PH - 8.3
FC - 0.2
TA - 146
Total chlorine - 0.2
CYA - 5
Salt - 700
Calcium hardness - 239
Store recommendations
- add 441 lbs salt (not using SWG yet, so will not be adding)
- pH - add 4 lbs of Lo’N slo (I added 2lbs to each of our 2 skimmers)
- add 5 lbs of stabilizer100 (will add in 2 hours, per store directions)
- add 2 lbs of shock (will add tonight, per store directions)
does this seem like it will set us up to get back to clear water, in appropriate ranges?
Thanks so much.
PH - 8.3
FC - 0.2
TA - 146
CYA - 5
Salt - 700
Thanks so much.
