- Nov 12, 2017
- 12,712
- Plaster
- Pentair Intellichlor IC-40
Remember, you'll be emptying the pool soon, 100%. So using pucks is a good solution for you, because you don't have the normal concerns about doing so. Whatever the pucks do to your CYA level won't really matter. You'll come back, measure your CYA level, and use the CYA/FC chart to reestablish your FC level for, what, a month or so. Then you'll be getting "brand new water." So puck away. An elevated CYA level might even help with your current FC loss issues, for that last month or so. I seem to recall some in the southern states run their non-swg pools about CYA50 to help with all the sun, anyway. Does that extra CYA sound right, Kim? Marty?
Whatever pucks you have left over, you can use to both chlorinate and add CYA after you get your new surface and new water. You can use solid CYA the first month to get you up to CYA30 or so, then use the pucks to gradually raise your CYA to SWG level, even though you won't have salt yet. With a little effort and some PoolMath, you'll reach your CYA of 70-80 right about the time you'll be adding salt.
