I've ordered a pool kit from Pool Warehouse and found a pool installer that is just installing the pool, cutting the dirt for the patio, back fill and dirt haul off. I will be contracting out the electrical, concrete and brick sitting/slight retaining wall. Here is a layout and a couple of mock ups I did on Sketchup. The pool will be a vinyl liner 16'x32' 48" steel wall 8' deep with liner over steel steps on shallow and and a liner over steel bench in the deep end. It will have two 24" sheer or rain falls in the deep end either side of the bench. I ordered the kit with the following Dark Blue Diamond 30 mil no border, flex flat gray coping, 2 gray skimmers, 7 gray returns (three for niche-less lights) and gray main drains. I removed the equipment and will be sourcing it local or via the internet. A little info about my backyard, no trees close, sloped lot towards the house on a golf course even with the senior tee box about 60 foot from my fence, the pump and filter will be between 30" -36" inches below the water line.
The equipment i'm going to go with will be Pentair, I'm looking at the following Easytouch 4, IC40, Pentair intelliflo i1 (011059), Clean and Clear Plus 320, Screen Logic 2, 1 actuator and 3 SR Smith Kelo or Treo Lights (not sure which yet).
I haven't ordered the equipment if anyone sees any problems or easier way I'm all ears. Not sure if I need the SR Smith power supply or if I can just power them off the Easytouch low voltage. I would like input on my choice of returns locations, I'm trying for a clockwise rotation with the bottom right skimmer being the main one due to wind direction (skimmer locations are set).
